A BFDI join to a control plane component has failed. If restart is supported for this join the BFD stub will maintain the current BFD protocol sessions until the failover timer fires.
Determine which control plane component has failed by using the indicated process id and investigate.
Warning
A BFDI join to a control plane component has failed. BFD entity index = %p1% Control plane entity type = %p2% Control plane entity index = %p3% Control plane component process ID = %p4%
| Name | Type |
| p1 | sInt32 |
| p2 | xInt32 |
| p3 | sInt32 |
| p4 | uInt32 |
